Reply
Has or will the RAX200 get the final WIFI 6 specs
blue13x
Hi.
I have been using the Netgear routers for some time now and looking into the getting the RAX200. I am aware that the final WIFI 6 specs has been finalized just recently.
Is or will the RAX200 adhere to ALL the WIFI 6 specs? I read that the older RAX120 already doesn't support some features, and would hate to pay that much for a router, only to find out later on that it doesnt support all the final WIFI 6 features.
Any thoughts on this?
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 13
avtella
Prodigy
Re: Has or will the RAX200 get the final WIFI 6 specs
The RAX120 qualitatively uses a superior chipset (Qualcomm), in SmallNetbuilder’s testing the RAX120 did the best in 5Ghz performance testing while the Broadcom chipset based router’s like the chipset in the RAX80/200 saw a weird dip in performance plots.
The RAX200 is basically a RAX80 with an extra 5Ghz band and 2.5 Gb with port but the main Broadcom WiFi chipset and CPU are the same.
Qualcomm usually has a better track record of implementation of new features in a properly working manner. Broadcom still has issues with things like MU-MIMO performance.
Message 2 of 13
avtella
Prodigy
But yeah none of the current routers support all AX features..... Even if chipset vendors promise support later on via an update for current devices I’d be weary. As mentioned previously at least with Broadcom newly added features aren’t necessarily activated in a properly functioning manner, more like just to check boxes. Qualcomm had declared that the QCA8074/8 chipset in the RAX120 supports all the draft AX features but things like uplink MU are missing, though downlink MU is enabled.
Message 3 of 13
avtella
Prodigy
If you want a full featured AX router, I’d hold off right now.
Message 4 of 13
blue13x
That still doesnt the answer of wifi 6 certification
Message 5 of 13
blue13x
So basically there is a chance things wont be supported. Better wait for v2
Message 6 of 13
avtella
Prodigy
Yep. I’m pretty certain current routers they won’t support all the features even at a later point. But as I said earlier don’t take even the WiFi 6 certification to necessarily mean that all those features will actually work well/cause issues in the first gen chipsets if any even manage to get fully certified in the first place.
Message 7 of 13
digitsnbits
Apprentice
There are quite a few Wifi6 certified routers now. Unfortunately none of them are made by
Netgear. The Asus RT-AX88U is WiFi 6 certified and it uses the Broadcom chipset.
Ever wonder why Netgear is absent from that list? Probably because their firmware side of all their wifi6 products are a complete disaster and the absolute stonewalling of acknowledgment of any existing problems.
Message 8 of 13
blue13x
I'm starting to believe that asus is the way to go. So far had good experience with netgear. Also the the netgear AX nighthawk routers look great.
Message 9 of 13
digitsnbits
Apprentice
I currently use the AX88U & the AX58U in a mesh setup and they work as advertised, with no issues even remotely close to what I experienced with Netgear. This is why my RAX80 is sitting in a box.
Save yourself a world of trouble and avoid Netgear.
Message 10 of 13
avtella
Prodigy
The AX88U does NOT support all AX features, SNB testing shows even in the unreleased beta firmware there’s a major performance issue with a massive dip in the 5Ghz performance charts. The Qualcomm chipsets are the only ones that are somewhat consistent performance wise, or RAX120 and others using the same chipset. Asus has one eventually coming out using that QCA8074 chipset.
Message 11 of 13
blue13x
But I also read that the RAX120 also lack crucial AX specs . This whole wifi 6 thing is a mess.
This whole bringing out hardware based on draft should be regulated. And these things are expensive.
Message 12 of 13
avtella
Prodigy
Yep you are correct, not all features have been enabled even on that one, but at least those enabled AX functions work properly like WPA3 and Downlink OFDMA unlike in the Broadcom based routers like the AX88U/GT-AX11000 or RAX80/200. The Broadcom units still have issues with MU-MIMO performance at times.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 1523 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
