- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Hourly disconnections - RAX45 (Every 60 minutes exactly)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router model: Night Hawk AX4300
Issue: For the past two weeks, every60 minutes, my connection will drop for 15-20 seconds, then restablish without issue and maintain without drops for 60 minutes, until it drops again. This issue is shared between devices on WiFI and ethernet alike.
I have been actively troubleshooting since it began, and have done all of your typical troubleshooting (i.e. firm ware upgrades, ethernet cable replacement, warrantied the router and replaced with a new one of the same model, verified that the issue fixes when I circumvent the router and hard wire directly from the wall into my CPU instead of wall -> router -> CPU. I've tried changing network settings, had my ISP verify that there were no connection issues showing on their end, etc.)
I'm stuck trying to figure out what the root of the cause is.
I've ensured that all devices on the network are not responsible, as I have removed them all from the network, and tested that the issue persists on a couple devices when nothing else is connected. It's clearly not an ISP issue since the connection issues vanish when the router is circumvented.
What more is there to try?
Thank you any help you all can provide and I am happy to provide logs and additional info at your request.
- Chase
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Hourly disconnections - RAX45 (Every 60 minutes exactly)
Are there LED indications seen when this happens on the router?
Is Armor, Access Controls or Traffic Meter enabled?
Is DST set correctly for your time zone?
- Mark as New
- Bookmark
- Subscribe
- Permalink
A: V1.0.4.100_2.0.64 (Confirmed most up to date my GearHead support)
A: The ISP is Hargray, I live in an apartment that is pre-wired so I do not have access to the providers Modem. I did check the service room connected to my apartment, and only found a fiber splitter box.
A: Will check next hour when it occurs again and update accordinly.
A: Armor is enabled, access control is not on, Traffic meter is not on
A: Yes, the current time shown is correct.
A: There's only 5 total networks in range, 2 of which are mine, 2 of the others are one persons 5ghz and 2.4ghz network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?A: The ISP is Hargray, I live in an apartment that is pre-wired so I do not have access to the providers Modem. I did check the service room connected to my apartment, and only found a fiber splitter box.
I would disable Armor to see if this problem still happens. This may take a full on factory reset and setup from scratch with out enabling Armor.
