- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
I can not find a way to turn WPS off on the RAX80
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was just going though the settings and one thing that should be able to turn off is the WPS feature.
Am I over looking this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I can not find a way to turn WPS off on the RAX80
There is support for the RAX80, including a manual, at the end of this link:
>>> RAX80 | Product | Support | NETGEAR<<<
See the section Specify WPS Settings.
If you want to disable the button, you may be out of luck.
Any reason why you want to do this? Maybe there are other ways of achieving the required outcome.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It can or is seen as a security risk.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think this is what you are looking for:
Go to:
Advanced Setings
Advanced Set Up
Wireless Settings
Under WPS settings, uncheck "Enable Router's PIN"
According to the help center:
Enable Router's PIN
You can configure the router's wireless settings or add a wireless client through WPS using the router's PIN only when the PIN is enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suggested that, but apparently the quest is to disable the WPS button.
No idea why.
- Mark as New
- Bookmark
- Subscribe
- Permalink
missed that on your original reply... seems like the option would do the trick sufficiently, but... 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
