Reply
I need to remove Netgear Armor from Nighthawk RAX35v2 Router. It's garbage worm and I want it gone
ketcham
Initiate
I just bought a  Nighthawk RAX35v2  and it forced this Armor crap on my Router. Nobody wants this junk and I need it completely removed or I will return this paper weight promptly!!! You shouldn't have to deal with any of this just because Netgear is greedy and wants to take advantage of people who know nothing about their network. I need a fix for this now please!!
Message 1 of 8
Guru
Re: I need to remove Netgear Armor from Nighthawk RAX35v2 Router. It's garbage worm and I want it
You can disabled it.
But armor is integrated into the firmware so there isn't a way to just "remove it"
https://kb.netgear.com/000060900/How-do-I-turn-NETGEAR-Armor-on-or-off-using-the-Nighthawk-or-Orbi-a...
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 8
ketcham
Initiate
Thanks but this is not at all usefull to me. I have already disabled. I don't want netgear spyware on my network and I will return this router and replace it with something less intrusive if it cannot be totally removed. I will return this item to the store this weekend.
Message 3 of 8
Newfiedrool
Virtuoso
Considering your browser probably tells a site more about you than Armor I would think it's the last of your worries to be honest plus your isp and DNS thrown in.
if it's not enabled there will be no communication unless you turn it on or subscribe to the service and to be honest all routers phone home even just for checking updates and i really don't think they are interested in us mortals.
Message 4 of 8
Guru
Netgear=Armor
Asus=aiprotection from trendmicro
Tp-LInk-Avira
etc.
most router manufacturers are incorporating some type of security. If you don't want it on the device at all, then buy an enterprise level device or build your own router so you can control its features.
https://arstechnica.com/gadgets/2016/01/numbers-dont-lie-its-time-to-build-your-own-router/
Otherwise it gets incorporated into the firmware. It doesn't have to be enabled.
Message 5 of 8
roger1955
Apprentice
No worries,
You just have to do a factory reset, it is the only way. When you do, don't enable it again.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 6 of 8
don544
And no where does it tell you you have to pay for the service when they promote it on the box , only afterwords do you get that info.
Message 7 of 8
Razor512
Virtuoso
Do a factory reset and then use your web browser to do the setup and NOT the nighthawk app.
That will keep the armor service from being enabled.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 730 views
  • 4 kudos
  • 6 in conversation
Announcements
Orbi WiFi 6E
