ussvalor
Dec 25, 2020Follower
I want to learn more about compatibility with Amazon Alexa and Google Assistant
Hello,
I know that Netgear is one of the few companies that makes routers that are compatible with Amazon Alexa and Google Assistant. Where can I find an explanation or demonstration of the available features? Are there videos available? Also, where can I find a list of compatible devices? I cannot find any mention of Amazon Alexa or Google Assistant on the Netgear website.
Thanks in advance.
1 Reply
first one is for compatible devices and 2nd is for commands available.
https://www.netgear.com/home/wifi/routers/amazon-alexa/
https://kb.netgear.com/000036882/Which-Alexa-commands-does-my-NETGEAR-router-support
https://www.netgear.com/home/wifi/routers/google-assistant/
