× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
IPv6 Filtering: Secured
Topology
Virtuoso
The RAX120 (and presumably other RAX-class routers) sets the “IPv6 Filtering” option to “Secured” by default (see ADVANCED | Advanced Setup | IPv6). The only information provided about this firewall setting in the User Manual is that “the router inspects both TCP and UDP packets” when it is enabled.
What specifically is "IPv6 Filtering" doing?  Insights from the forum community will be most appreciated.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 1
Discussion stats
  • 0 replies
  • 1710 views
  • 2 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
