× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Link Aggregation Race Conditions RAX200 and SB8200
Nano_Pico
Guide
I just purchased the RAX200 and have configured it for link aggregation with the SB8200.  When running properly I achieve download speeds of 1.2 Gigs.  Every 24 hours or so the download speeds gor to 3 or 4 Megs.  If I unplug one of the ethernet cables to speed goes back to 950 Megs or so.  I can then plug in the cable I had disconnected and get back to the 1.2 Gig speeds.
My guess is that this is caused by a race condition. The RAX200 is showing that more than 4 Billion packets have been receiveed in 24 hours but very few packets have been transmitted.
I don't want to have to do this everyday.  Any thoughts on how to correct this?
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 3
Guru
Re: Link Aggregation Race Conditions RAX200 and SB8200
I wouldn't use the link aggregation with the sb8200.
Disable it and use the gigabit connection. You loose the over provisioning from your isp but you're connection will be more stable.
Arris is aware of the issue with the SB8200.
Message 2 of 3
Nano_Pico
Guide
Yes, the link is very stable if the WAN LAG is disabled on the RAX200
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 871 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
