- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Losing WiFi Signal RAX48
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Losing WiFi Signal RAX48
- Mark as New
- Bookmark
- Subscribe
- Permalink
it really shouldn't matter. that switch is a pretty basic one and it shouldn't cause an issue.
Did you try different cables or different ports on the router/switch?
Is the router new?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried the switch in all 4 Ethernet ports on the RAX48 with the same results. Tried a new cable that I tested with a Fluke Cat5&6 tester and the cable tested good.
It’s frustrating. Wireless signal is great, just really depend on my wired ports throughout the house as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The t25 does have 2x ethernet ports on the back of it. You're not hooking anything to that are you?
Because even through there's 2, xfinity only supports 1 public ip address. Meaning only 1 device can be connected.
You might still be in your support window.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The extra ports I’m trying to use are on the RAX48.
Thanks for all your assistance thus far. This is beyond frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would try contacting support.
