× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Need part number for a/c adapter for AX4300
Ford8725
Follower
n/a
Message 1 of 3
Guru
Re: Need part number for a/c adapter for AX4300
AX4300 is a speed, not a model.
Do you have the old adapter?
Netgear doesn't sell power adapters so usually you have to buy one with matching capabilities 3rd party or from ebay.
Message 2 of 3
Netgear does not sell replacement power adapters. Any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions.
Look at the device you own. It will have a label that shows what you need.
model number
The manual will have the information too.
Plug the details into your favourite on-line store, or visit a local shop.
Message 3 of 3
Discussion stats
  • 2 replies
  • 527 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
