Reply
Netgear Nighthawk RAX75 - wifi dropping frequently
pratik82in
Follower
I bought Netgear Nighthawk AX6 - RAX75 from costco recently and I have installed it as extenion to existing Verizon Fios.
Also I have turned off wifi from fios router to avoid any channel conflict.
I am experiencing frequently wifi dropping in all connected devices. it keeps loosing internet connection and reconnects randomly. I have updated it to recent firmware and still issue exists.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Moderator
Re: Netgear Nighthawk RAX75 - wifi dropping frequently
Hello pratik82in,
Welcome to the community! Please note that your recently purchased device is provided with 90 days of complimentary support from our support team which can be accessed by registering your device using the link below.
https://www.netgear.com/support/default.aspx
Would you mind telling me if the issue occurs on all devices connected to the network or only to specific ones? Also, you may want to try disabling AX mode to see if the issue persists.
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1120 views
  • 0 kudos
  • 2 in conversation
Announcements
