a929s0216's avatar
a929s0216
Follower
Dec 28, 2020
Netgear RAX45 doesn't block the website based on keywords/domain
Turn on the access control then site blcking as "always"
Put the keywords for the blocking as floows:
epic games
epicgmaes.com
cnbc.com
eveonline.com
saved the settings and restarted the router. None of the site/keywords been blocked. All devices still have the access.
Need support here. Tks.
Firmware version: V1.0.2.66_2.0.42
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
