- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New - RAX20 Firmware Version 1.0.10.110 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Security Fixes: 3/14/2022
Fixes security vulnerabilities
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Firmware Update Instructions
Download Link: https://kb.netgear.com/000064690/RAX20-Firmware-Version-1-0-10-110
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RAX20.aspx#docs.
Manually update router FW:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
A factory reset and setup from scratch maybe needed if problems are encountered after applying FW updates:
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Wireless AX Router Nighthawk (WiFi 6) (1)
Let us know how it works for you in this thread...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RAX20 Firmware Version 1.0.10.110 Released
Update Breaks Advanced Tab
Updated today (2022-03-24) to Firmware Version V1.0.10.110_2.0.72 and now I cannot access the Advanced tab on the router setting page.
I had the exact same issue, i had to power off my RAX20 at the wall and restart it for the Advanced tab to work again.
No problem now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was a factory reset and setup from scratch performed after updating FW?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Was a factory reset and setup from scratch performed after updating FW?
You can't do either with automated FW update and then you're locked out of the Advanced tab with a frozen GUI, the only option in my case was to hard power off and on again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Thank you.
@DeezN wrote:
Nighthawk app is coming up with an issue when in device manager claiming the router is offline despite it providing me with internet. Also getting the cdil-api-fail error message when I go into it on the app. Tired of troubleshooting for an hour. RAX50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear RAX20 - Advanced Setup - Router Information - CPU Load
CPU1: 1.75% CPU2: 1.32% CPU3: 1.47%
This firmware still only shows 3 cores instead of 4.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAX20 Firmware Version 1.0.11.112 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
