- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AX12 WiFi Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have a Garmin Forerunner 945 sport watch and am having issues with syncing my Spotify playlists to the watch. I finds all the playlists and starts syncing, but stops after about 7-9% each time then fails. I've tested the watch on other WiFi networks and it works fine which leads me to believe there is an issue with how the watch is staying connected during the sync. The best i can determine is it must have something to do with WiFi 6 and OFDMA. Has any had this problem and knows how to fix it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Nighthawk AX12 WiFi Issues
Hi FlipNBC,
Were you able to sort your issue out?
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
No, I still can't Sync any Spotify or other music service (tried Amazon also) to the watch with this WiFi Router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi FlipNBC,
May you try disabling AX WiFi in the admin settings of the router.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I found the problem to be the 5Ghz band setting of 4803 Mbps (160MHz). Switched it to 80Hz and the router had been stable for 12 Hours. I have now re-enabled my AX settings to see if it will continue to be stable. Speed tests show no difference whether using 160 MHz or 80 MHz.
Hope this helps others.
Router:. RAX120v2
Firmware: V1.2.0.16
