Reply
Nighthawk App
jayel49
Nighthawk App
I'm confused with the WiFi Analytics section of this app.
When I check my Internet speed, on the Internet Speed section it's 32.15 Mbps.  When I use the Home Testing tab, on the Wifi Analytics section, to test the conditions in my living room it shows a speed of 433 Mpbs.
It's surely not possible for the speed in my living room to be greater than the overall download speed?  Am I miss-understanding the figures?
Mike
Message 1 of 2
Accepted Solutions
Guru
Re: Nighthawk App
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App and know how to work it better than those of us who follow this "general router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Thank you,
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 2
All Replies
Guru
Re: Nighthawk App
Thank you,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 155 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
