- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk RAX120 PS4 remote play and Steam Link
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I recently bought a Nighthawk RAX120. I'm trying to stream using remote play on my PS4 and steam link from my PC. The issue is this does not work very well due to constant stuttering. It's like a slide show. I've tried switching between 2.4 and 5ghz, this made no difference. Turning off WMM is QoS seemed to help slightly but games remain unplayable due to stutter and visual disturbances and my download speed went from 165 to 27 which isn't acceptable.
I tested my speed and enabled Upstream QoS (10Mbps), this helped slightly but leads to an eventual disconnect after 30 seconds to a minute.
I used to do this with the Nighthawk R8000P with the devices connected to the same 5ghz SSID with out any issue whatsoever so I know the fault lies with the RAX120.
Can anyone help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk RAX120 PS4 remote play and Steam Link
Hello shemsureshot,
May you check to see if you there is a firmware update available on the newly purchased router. Furthermore, your device is provided with 90 days of complimentary support with our support team which you can access using the link below.
https://www.netgear.com/support/default.aspx
Christian
