Discussion stats
  • 5 replies
  • 268 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Nighthawk RAX45 Doesn't connect to internet
I'm trying to install a Nighthawk RAX45 router. It appears to connect to the internet, but Firefox can't find any websites, and Outlook doesn't connect. Same symptoms with Lenovo P1, and W540, running Windows 10.
Thank you!
Message 1 of 6
Accepted Solutions
Highlighted
Guru
Re: Nighthawk RAX45 Doesn't connect to internet
What modem/gateway is it connected to?
Firmware on the router?
CAX80->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 2 of 6
All Replies
Highlighted
Guru
Message 2 of 6
Highlighted
Thank you for your reply! It's connected to a Spectrum modem. I just got it working by updating the firmware, with an ethernet connection.
Message 3 of 6
Highlighted
Glad you got it to work, but if you hit further problems then this both will not get you very far:
There are lots of "spectrum" modem out there. For further help, tell people the make and model number.
I suspect that @plemans was trying to determine if your "modem" is really a modem/router. That could explain the symptoms you saw. They may come back again. Be prepared.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 6
Highlighted
Thank you! It is a modem/router, but because I'm using a router, Spectrum disabled the router in the modem/router. It worked fine for many years with a Netgear router, until the router failed, and I just bought the Nighthawk Rax45.
Message 5 of 6
Highlighted
Always worrying. Having to rely on someone else to configure your devices. Especially an ISP.
Just another user.
Message 6 of 6
