Reply
Highlighted
Nighthawk RAX80 Only allows 4 IP Address Reservations
I can only add 4 ip addresses reservations when I go to Advanced->Lan Setup->Address Reservation. Why is there a limit on IP addresses reservations?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 4
Highlighted
NETGEAR Moderator
Re: Nighthawk RAX80 Only allows 4 IP Address Reservations
Hi sajin007,
May you let us know what firmware version your router is on? You should not be limited to just 4 IP addresses.
Christian
Message 2 of 4
Highlighted
Hi,
My router Firmware Version is V1.0.1.70_1.0.30, this is the most recent firmware.
Thanks,
Sajin
Message 3 of 4
Highlighted
Heads up, but 1.0.1.70_1.0.30 is not the latest, see this link below, it should be:
1.0.3.88_1.0.41
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/New-Firmware-Released-RAX80-1-0-3-...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 292 views
  • 0 kudos
  • 3 in conversation
Announcements
