× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk X6 Router config with new Fiber added
Mrteeth2005
Follower
I just upgraded to 500mbps fiber today. Connected directly to my computer from the IPS's modem, I'm getting around 500meg, as it should. However, everything running on my Netgear Nighthawk X6 is still at 150-180mbps, which is what I was getting before the switch. What can I do to throttle it up so it can get around 400mbps? I know I won't be able to get all 500mg through wifi.
Thanks
Message 1 of 3
Guru
Re: Nighthawk X6 Router config with new Fiber added
Try doing a factory reset and reinstall.
Make sure during the install to leave qos, access control, parental controls, and traffic monitoring all disabled.
Message 2 of 3
Guru
Thanks
Message 3 of 3
Discussion stats
  • 2 replies
  • 511 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
