- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Ethernet Half the Speed of WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi Router and two Satellites working pretty well but just noticed an issue with one of the Satellites.
I have a PC plugged into a Satellite via Ethernet which consistently gets download speeds of ~250Mbps yet the same PC via WiFi is always getting 600Mbps. I've tried recycling the Satellite, syncing with the Router, changing Ethernet cables (CAT 6 and CAT 7) and the tests I've done show a much slower wired connection. The Router this Satellite syncs with is no more than 25' away, directly on the other side of the wall.
Can anyone suggest anything?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the PC get good speeds if connected at the RBR?
Does a different PC experience same thing at RBS?
Be sure the PCs ethernet adapter drivers are up to date.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Ethernet Half the Speed of WiFi
other side of the wall..??
test it without the wall
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. I just tried that and it's looking more like a notebook NIC driver issue. This is my wife's work computer and their IT department locks down end-user installations but it's my guess that they haven't updated manufacturer (Lenovo) driver updates. The speeds on the RBR were the same both for wired and Wireless. I'll be opening up a ticket with their support.
I appreciater it!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully they can get updated. Good Luck.
