× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Port Forwarding rules disappearing!! 2022 Version!
SniperStorm
Tutor
Today I noticed that you could not access my telnet port from the outside.  I looked at my port forwarding rules and they are all BLANK!( I will ad screen shots).  If I goto try to add them again you get a screen that says "Port conflict with other service".
If I add a new port that I know is not set up it will let me do it.
Just a new note if anyone can help.
 I already looked up this issues on the forums and it seem to be a constant issue with many routers leading to think its a software issue. I have seen many people complain about this but cannot find a solution.
It seems like the rules are there, but are hidden from view and not working.
Message 1 of 8
回复: Port Forwarding rules disappearing!! 2022 Version!
Hi @SniperStorm
What is the FW version you use ?
Message 2 of 8
SniperStorm
Tutor
Re: Port Forwarding rules disappearing!! 2022 Version!
V1.0.10.82_2.0.39  Is my firmware version.  It does not even matter. This issue seems to have been going on for years for many people on many  netgear routers. I have to reload a saved config to be able to see the ports again,
Message 3 of 8
JenniferMathis
Is it solved?
Message 4 of 8
SniperStorm
Tutor
It has. Not been resolved. Netgear sends me beta firmware that never fixes it. I actually believe is interface is causing the problem with the web browser. Like it's programmed incorrectly. It's been 6 months and no fix. I brought a linksys 6e and it's working trouble free. Said bubbye to $500
Message 5 of 8
JenniferMathis
R.I.P $500
Message 6 of 8
Guru
Message 7 of 8
JamesMagill
Is it a solution? I've noticed that, too, but I'm not sure if the problem has been resolved.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1658 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
