- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problems With Web Page Rendering Since August Firmware Update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ever since the latest frimware update, which I installed in August I have had web page rendering issues. Often I have to reload a web page 3 or 4 times to get the proper rendering. Often the web pages dont load at all at first and it takes 3 or 4 tries.
I plugged my PC directly into my modem and this goes away.
This proves it is caused by the router. But I need to use my router!!!
How do I get this fixed?? I did a factory reset and this didnt help.
AC1750 Smart WIFi Router R6400v2
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try downgrading a version.
I've seen mutliple people with issues on the newer versions that have been fixed with a simple downgrade.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Problems With Web Page Rendering Since August Firmware Update
Your right. I did work. I had trouble with that firmware upgrade from the very beginning. It didnt install as they normally do. What a mess. I hadn't relaized at first that it was a problem. I had done a factory reset and the problem persisted. Going back to the previous firmware worked.
Thanks
