JJI1
Sep 21, 2020Tutor
R8000P vs RAX120
I am thinking of going with the rax120 is this better then my current R8000p. The rax is only dual band where the 8000p is tri band. I really don't need wifi 6 no devices as of yet. Would this still be an upgrade over what I have. I really have no issues with current setup just looking to upgrade if it makes sense
Thank You
would it make a difference...Maybe?
AX devices are better at concurrent usage. meaning more than 1 device can broadcast at a time. But the R8000P is triband so you can have them seperated out between all 3 bands anyway.
and as you said, you don't have any ax devices so you wont see a benefit there.
If it was me? I'd hold off until you need an AX router. the R8000P is quite capable and if its doing everything you need, I would just wait on the AX firmware to stabalize and for features to improve.
Plus wifi 6E is going to be coming out at some point :)
- JJI1Tutor
JJI1 wrote:I am thinking of going with the rax120 is this better then my current R8000p. The rax is only dual band where the 8000p is tri band. I really don't need wifi 6 no devices as of yet. Would this still be an upgrade over what I have. I really have no issues with current setup just looking to upgrade if it makes sense
Thank YouI cant see how to edit a post so I will add it here. I have about 25 devices. between tv,ipads,iphones and 2 xboxs
- JJI1TutorThanks appreciate it. I always seem to be looking at the next best thing. Since ive had current one for awhile.
Ill wait for now
Thanks again for the help
