- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX 120 authenticaton error
- Mark as New
- Bookmark
- Subscribe
- Permalink
My sole 85 treadmill will not connect to wifi. I think it is an authentication error. Any help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX 120 authenticaton error
does the sole connect through an app?
Make sure the phone/device your using to setup the sole is on 2.4ghz during setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did setup a guess 2.4 and tried that but it did not connect. I have smart connect turned on.
I am not sure what CM2000-> Arris AX11000 W31-> GS716v2-> WAX***-AP means?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SWARTZC wrote:I did setup a guess 2.4 and tried that but it did not connect. I have smart connect turned on.
the cm2000****** is just my signature for what my current setup is.
Try turning off your smart connect. Keep your 2.4ghz ssid/password with the same one that you'd use with smart connect on and use something else for 5ghz. then connect your phone to the 2.4ghz and try setup.
what modem/gateway is the router connected to.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok- I can try that. Although I really do not want to take off smart connect.
The 2.4 guest worked when I took of all security. It is def a security issue for some reason.
I would think as long as there is a password required it is not going to work, even if I take off smart connect.
I have 20+ products connected to wifi and this is the only issue I have had with connecting.
My moden is an ARRIS SB6190
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can turn smart connect back on once you get it connected. Its just to ensure that your phone and treadmill are both on the 2.4ghz during setup. Thats why you'll keep the 2.4ghz with the same ssid that you'll use with smart connect on.
