Reply
RAX 200 NTP Time sync
Collin1997
Follower
Every hour or so, I get disconnected from online games. I’ve done every troubleshooting step under the sun and the only thing that sticks out is the fact that in the logs I’m seeing [Time Synchronized with NTP server] whenever I get briefly disconnected. Things such as streaming aren’t really impacted because the disconnect is so short, but it’s beyond frustrating to keep timing out from online games.
Why does the router keep time syncing so often?
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: RAX 200 NTP Time sync
Hi Collin1997,
I would check to see if your router is due for a firmware update.
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 269 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
