× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX120 - Netgear Armor
kc6108
Luminary
I can’t get Netgear Armor to activate. When I click “Activate Trial” (using the Nighthawk app) I receive an error. Anyone else experience this? Latest firmware... version 1.0.2.136
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Pistole
Guide
Re: RAX120 - Netgear Armor
Hi I have exacly the same problem on my RAX120. The last firmware same as you.
Ik have bought Bitdefender Armor and I can use it on my pc's but in wont't activate on my router.
In the Nighthawk app keeps coming with activate trial.on the 20 october.
I have reset the router to factory defaults also without result.
I have sent a message to Christian, finally resulting in him making a support ticket.
Yesterday I've been called by support and after one hour of trying trought Teamviewer on my pc sending proof that I realy bougt Armor, support has sent the problem to Bitdefender.
After 2 or 3 day's they come with an answer I hope.
I myself think it is a problem in the syncing between the 2 company's. It is also very annoing that is so hard to get the problem fixed.
Grtz Paul
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 606 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
