- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 doesn't save and/or edit port forwarding setings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now I needed to modify one setting and when I click EDIT it just opens Add custom service with all empty fields - list of device IP's is empty too. Ok, I wanna add new port forwarding servcice without editing the existing one - but the router just does nothing when I click Save.
What is happening, NETGEAR? So expensive product and so much bugs and no support at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 doesn't save and/or edit port forwarding setings
Hi alud7_ru,
Did this issue occur with previous firmware versions? You may try reverting back a firmware version to see if the issue persists.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yesterday I did a factory reset because I wanted to clean install the router. After the reset the devices list on my MacBook kept empty and I cloud not create any port forwardings.
On the IOS app the list was normal filled.
I have installed the previous Firmware Version V1.0.1.115 and the list was again filled with my devices. I updated again to Firmware Version V1.0.1.122 and the list was again empty.
Rest me no other option than again go back to Firmware Version V1.0.1.115 and keep working on that version.
There is something very broken in the Firmware Version V1.0.1.122.
