- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 randomly resets my CM 1000 modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all! Not super knowledgeable about tech and the like. I recently purchased the RAX120 as an upgrade from my R8000P. Since having this new router, my modem randomly reboots. I tried a couple different things (including contacting ISP, resets on all devices, trying multiple connection variations between devices, etc.) before coming to the conclusion that when the RAX120 router is connected to the CM1000 modem, the CM1000 will completely reboot very often (especially when using streaming services). This does not happen when the R8000P and CM1000 are connected. I haven't altered a lot of the default settings on the RAX120 and it is running firmware version V1.0.1.136. I haven't been able to find any information specifically addressing this or whether the RAX120 and CM1000 are incompatible. Is this a known issue, is there a solution, or will someone be kind enough to help me out with this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 randomly resets my CM 1000 modem?
Hi Ser_Raven,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
