× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX20 does it have internal modem and if it does how do I connect a coaxial cable
HoppyJim
Follower
Model: Dual Band, RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 2
rinthos
Luminary
Re: RAX20 does it have internal modem and if it does how do I connect a coaxial cable
No the RAX20 does NOT contain a modem, t's only a router.
You can find a list of Netgear Cable Modems here which you can add in addition to your RAX20 if preferred: https://www.netgear.com/home/products/networking/cable-modems/
Or you can replace your RAX20 with a Router/Modem combo device, which you can find a list of here: https://www.netgear.com/home/products/networking/cable-modem-routers/
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 582 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
