Reply
RAX200 (AX12) : GUI not responsive
lowrisk
Tutor
I'm not sure what to do but I have a lot of issue with the GUI, I managed to turned of after 20 try the WiFi schedule, no I don't need it anymore, can't turn it off, the tick box is not working, I can't seems to disable the WPS neither ...
Tried from different clients, also with safari, chrome , firefox , all have the same issue...
I did a few factory restor recently hope I won't have to do it again
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 3
Accepted Solutions
Re: RAX200 (AX12) : GUI not responsive
@lowrisk wrote:
I'm not sure what to do but I have a lot of issue with the GUI, I managed to turned of after 20 try the WiFi schedule, no I don't need it anymore, can't turn it off, the tick box is not working...
I'm afraid I can't follow what is going on here. Probably my fault.
What are you turning off? The video is hard to follow.
Is this an attempt to control the wifi?
I don't get this bit:
"I managed to turned of after 20 try the WiFi schedule, no I don't need it anymore, can't turn it off"
Turn off the wifi schedule?
If you mean you want to turn off the WPS LED, you can't.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
All Replies
Just another user.
Message 2 of 3
lowrisk
Tutor
Sorry my post was very bad alright,
Basicly I coudnt disable the Radio schedule for 5Ghz (turn on/off at given time)
I coudnt disable the WPS option neither
Anyway the only solution I found was to factory reset, which I did.
Thank you and sorry for the post.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1107 views
  • 0 kudos
  • 2 in conversation
Announcements
