Reply
RAX200 Only Wifi Light on - can't connect
Trex6
I just received the nighthawk router today. However when I switch on no lights are on except the wifi light below. connecting an ethernet cable, mac says it is unplugged. The wifi is not visible and I couldn't find any way to connect to it.
is this router broken from the factory or am I missing something?
I left it on for more than 30 mins, nothing changed.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 3
Accepted Solutions
Trex6
Re: RAX200 Only Wifi Light on - can't connect
the power was not on neither so sent back the device. the one which came today works.
Message 2 of 3
All Replies
Trex6
Message 2 of 3
Christian_R
NETGEAR Employee Retired
Hi Trex6,
Thanks for providing an update on your post as it may help others in the future!
Christian
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 555 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
