- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX200 keeps dropping wifi & internet for no more than ten days
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried almost every firmware including the latest one.
Some times it drops 5g. Sometime it drops 5g and 2.4g. Sometimes it drops 5g, 2.4g and internet. I add a fan outside. It's not the heat reason.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX200 keeps dropping wifi & internet for no more than ten days
What modem/gateway is it connected to?
When it drops, what actually happens? Does that specific band stop broadcasting? Do devices connect but say "connected, no internet", What actually happens?
Are you using smart connect? Does it happen if you disable it?
Try setting the "up to ****mbps" speeds to "up to 2400mbps". The RAX200 needs to use the DFS frequencies to hit 4800mbps and if you're in an area with dfs broadcasts, the switching could cause issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem I use is China Telecom😁.
When it drops, sometimes I can connect to the console, sometime I cannot. Just like I don't connect to Netgear. I think the system crashes.
I don't use smart connect.
Could I use RAX120 firmware to refresh the system?😄
Many thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
what chinese telecom modem is it?
No, you can't use the RAX120's firmware as its different hardware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
China Telecom,GPON ONU
中国电信,天翼网关
