- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX35 - Bricked after installing the latest firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
After installing the latest firmware on my RAX35 at first the wifi won't turn and then i did restart, now it won't even connect to the internet and wifi is also not turning on. I am unable to configure it using wired ethernet because it requires internet which the router it self can't connect. I have my other router that has no problem connecting to internet via my ISP's modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX35 - Bricked after installing the latest firmware
What modem is it connecting to?
What are the led's on it doing?
You don't need internet to access the routers gui. You should be able to connect/navigate by hardwiring into it.
What firmware did you try to install? Did you do it via the app or hardwired? (I'd recommend hardwired for firmware updates)
Have you just tried starting over and factory resetting? Pushing and holding the reset button for 7-15 seconds while its powered on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The firmware i installed is RAX35-V1.0.3.80_1.0.1
I did the update wired.
I tried resetting multiple times and did not helped at all.
The modem is a fiber modem, i am connected to it's ethernet port.
When I go to router gui and it keeps on doing the internet check.
Tried going to basicsetting.htm but it is not found see attached.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which fibre modem is it? this is key as many are fibre modems with an integrated router. Which can cause issues when using the routerlogin address.
If you disconnect it from the fibre modem, reboot the router, and then connect to it, does it work (for accessing)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
some fibre gateways or gateway/routers need specific settings. Its why i asked for a model number.
