Reply
RAX40 slow wired ethernet ports in AP mode
ronald_fr
Luminary
I put the RAX40 in AP mode with a good connection to the main router (SFR BOX NB7 giving 500-800Mbps).
Wireless connections run fast; no issue.
BUT internet access via the wired ports on the RAX40 are limited to about 250Mbps (speedtest.net).
I tested to connect the main router to one of the 4 wired ports instead the yellow (WAN)
  • Now the wired ports run now at the main router speed (500-800Mbps)
  • And the wireless connections are down.
Thanks for help
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 3
Accepted Solutions
ronald_fr
Luminary
Re: RAX40 slow wired ethernet ports in AP mode
My idea was to use:
        wifi (working well)
        and 2 ethernet ports
on the RAX40 being connected to the main router from the Internet Provider, so I can't switch out.
And if the router is configured as as Router and not a "Wifi Access Point", internet ports run at full speed.
Thanks
Ronald
Message 3 of 3
All Replies
Christian_R
NETGEAR Employee Retired
ronald_fr,
This may sound silly, but have you tried switching out the ethernet ports used on the RAX40?
Christian
Message 2 of 3
ronald_fr
Luminary
My idea was to use:
        wifi (working well)
Thanks
Ronald
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1890 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
