Reply
RAX70 USB port
F8Crusader
RAX70 USB port
The router doesn't recognize my printer on the USB Port.
Message 1 of 3
Accepted Solutions
Re: RAX70 USB port
Impossible to tell what might be happening given so little information.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
A quick search suggests that your device does not support USB printers.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
All Replies
Re: RAX70 USB port
Support | NETGEAR
Just another user.
Message 2 of 3
F8Crusader
Re: RAX70 USB port
That answered my question. 4+ hours with Netgear support answered nothing. They couldn't figure it out. Replaced the router as they discovered the reset button didn't work. But no answers. A few days later, one of their support agents looked at my problem and promptly emailed that mt router USB port didn't support printers.
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 647 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
