Punster's avatar
Punster
RAX75/80 Consistantly drops speed on both Ethernet and WiFI
I purchased the RAX75/80 from Costco a few months ago and have it connected to a CM1100 Cable modem,.  I have GB Service with Cox Internet.  It will maintain 950-990 MBPS (ethernet)  for about 24 hours, WiFi is extremely fast as well.  However, it will drop sharply after about 24 hours or so to 150-280 on the ethernet port and the WiFi will be extremely slow as well.  I've updated to the latest firmware and still nada.  Once I reset the modem everything is fine for a while.  QOS is not enabled.  I got the usual Factory Reset your router advice from Support just before my free support ran out.  Has anyone solved this issue with a factory reset?
I've seen several suggestions on getting this to work in the community but so far nothing I've tried has been successful.  I bought this thinking it would be better than the Cox panoramic wifi modem which is a piece of garbage.  I've been extremely disappointed so far.
  • plemans's avatar
    Are you using wan port aggregation?
    if so, i'd highly recommend disabling it on the cm1100 and the RAX and just using a single connection. I've found many ISP's have issues with port aggregation.
    • Punster's avatar
      Punster
      I've attempted to get port aggregation to work with no success so I'm ust using a single connection.
      • plemans's avatar
        so its solid for 24 hours and then drops?
        have you tried connecting a pc to the modem and using just that for 24+ hours to see if its a modem or a router issue?
