- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX75 Erratic Behavior and Instability
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX75 Erratic Behavior and Instability
"power hits' or surges are great at wrecking sensitive electronics. Especially the newer, more advanced they get.
If it is a corrupt firmware issue, rebooting won't fix the problem. Neither will resetting it as resetting only removes old settings.
What I'd try? reinstall the firmware manually over a hardwired connection, factory reset it, and then reinstall it.
I get that you have a time sensitive window but if its corrupt firmware, the reinstall fixes it, if its a bad/corrupt setting, the factory reset fixes it.
If you do both at once, you've covered your bases. After getting everything reset/reinstalled, make a backup. I wouldn't use one now in case it is a bad firmware/setting causing the issue.
