× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX75- firmware update issue
Mame22
Follower
Hello,
I cannot update my router firmware my using the app, it just thinks then states try again?
Anyone have suggestions to adress this issue?
Message 1 of 2
Guru
Re: RAX75- firmware update issue
I'd highly recommend against updating using the app. Its usually where we see the most issues, corrupt firmware problems crop up.
I'd hardwiring into the router and update it manually.
the manual walks you through how to update firmware manually.
https://www.netgear.com/support/product/rax75.aspx
Message 2 of 2
Discussion stats
  • 1 reply
  • 554 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
