× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80 Factory reset after restart
Guyver99
Follower
Problem:
RAX80 reverts to factory settings after software or hard restart.  It won't save any settings that requires a restart.  I've see many discussion about this issue but none of them have a solution.   The most useful info I got was,
from NickR40 2yrs ago:
"I think I may have identified the problem. I was able to telnet into the router and can see that the jffs devices have space issues.
On mtd:data the httpd_dbg.log file has grown to consume most of the device and any attempt I make to delete or truncate the log file just tells me that i can’t do it because there is no space on the device."
Things I've tried:
- Downgrade/upgrade to diff firmware most current "1.0.4.120" to any of the 4 avil ones
- 30,30,30 but I know it won't work on ARMs router but tried anyway...
- Hard reset with the button and pin
- Soft reset from the backup/restore menu
Hoping someone can expand further on the possible "jffs devices space issues" that may have caused this problem as I know I'm not the only one.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 1
Discussion stats
  • 0 replies
  • 945 views
  • 1 kudo
  • 1 in conversation
Announcements
Orbi WiFi 7
