Discussion stats
  • 11 replies
  • 1217 views
  • 6 kudos
  • 5 in conversation
Announcements
Top Contributors
Reply
Highlighted
Guru
RAX80 Firmware Version 1.0.1.64 -Channels 1, 11, 12, and 13 will no longer be used when the 2.4 GHz
RAX80 Firmware Version 1.0.1.64 says:
Bug Fixes:
  • Channels 1, 11, 12, and 13 will no longer be used when the 2.4 GHz channel is set to Auto.
Uh waht - this does not make any sense to me. @Christian_R  please?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 12
Highlighted
Guru
Re: RAX80 Firmware Version 1.0.1.64 -Channels 1, 11, 12, and 13 will no longer be used when the 2.4
I'd have to agree. I usually recommend 1-6-11 for people with 2.4ghz congestion problems.
CAX80->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 2 of 12
Highlighted
Apprentice
My router is on the latest firmware (64) and can confirm that the router still selects channel 1 when set in auto mode.
Incidentally, when channel 1 is active, nothing can connect to the 2.4ghz channel.
Is it a bug in the release notes or a bug in the router they were trying to prevent with this change?
Either way, channel 1 is still used in auto mode.
Message 3 of 12
Highlighted
Apprentice
@Christian_RDo you have some news about this?
Message 4 of 12
Highlighted
NETGEAR Moderator
Hello Everyone,
The following 2.4GHz channels will no longer be used when set to auto. However, you will still have the option to select channels 1,6, and 11 but will need to be done manually.
Christian
Message 5 of 12
Highlighted
Guru
@Christian_R what is the idea behind this (strange) design change?
Does the same apply to EU versions for the channels 1, 7, and 13 then?
Message 6 of 12
Highlighted
Guru
 Why should the the channels 11, 12, and 13 (as per the release notes) be masked? Sorry, this makes zero sense to me. And the incomplete and changing information coming frok Netgear is concerning at.least. @Christian_R
Message 7 of 12
Highlighted
Apprentice
1st question is why?
2nd question, I have this firmware & my router selected channel 1 in auto mode (there's a screenshot in the other thread).
Message 8 of 12
Highlighted
NETGEAR Moderator
Hello schumaku and GabboCH,
2.4GHz AUTO Channel will give top priority to select 2, 3, 4, 5, 7, 8, 9, 10, 12 (EU) and if the these channels are not available it will select Ch 6 & 13 and if these channels are occupied it will select Ch 1 & 11.
The reason for NOT selecting Ch 1 & 11 in NA was due to FCC Band Edge Transmit Power limitation.
Christian
Message 9 of 12
Highlighted
Prodigy
Problem is this causes overlap on non-overlapping channels. In my neighborhood practically the only devices not on 1/6/11 are the Netgear devices. This is kind of annoying.
Message 10 of 12
Highlighted
Prodigy
How is causing more interference a solution.
Message 11 of 12
Highlighted
Apprentice
Interestingly, In the release notes this comment has now been changed to "2.4G auto Channel Selection algorithm improvements".
Message 12 of 12
