- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX80 How to "Disable" Privacy Separator
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Netgear/Nighthawk/RAX80 router. I need to "Disable" the Privacy Separator but am unable to locate it. I need to know how to access the "Privacy Separator"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX80 How to "Disable" Privacy Separator
What is telling you that you need to disable "the privacy seperator"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem I'm having is, my devices (laptop/phone) are no longer able to "communicate" with my printer. My printer is "WiFi" and set up as "WiFi".
In troubleshooting why my printer is not comminicating with my devices (laptop/phone) an error message popped up saying to check my "privacy separator and disable it". Thank you in advance 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
What printer do you have?
Is the guest network enabled on the router and is the printer connected to it?
Is your network on the pc/laptops set to private or public?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What printer do you have? Brother/ HL-L2395DW
Is the guest network enabled on the router - NO and
is the printer connected to it, YES PRINTER IS CONNECTED TO THE ROUTER via WI-FI no hard cables are connected between Router and Printer? Printer stopped working when the "security" feature kicked in on the "router". The security feature is no longer active.
Is your network on the pc/laptops set to private or public? It should be set to Private.
What are your thoughts? Thank you so very much for your feedback and help 🙂
