× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80 Short Preamble in 5GHz
mateverywhere
I've never been able to get my RAX80 to save 'Short Preamble' against the 5GHz network. For the 2.4, it saves without issue.
Using the latest firmware as of today. Not using Smart Connect.
Has anyone been able to make 5GHz work with Short Preamble? How?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 5
mcleveland92
Re: RAX80 Short Preamble in 5GHz
I have not seen or found a soluton for this? Anyone?
Message 2 of 5
mateverywhere
No solution, still. Pinging it back up to attention, hopefully.
Other settings are
- AX enabled
- WMM enabled
- OFDMA enabled
Message 3 of 5
microchip8
Master
I have a RAX43 and am also unable to set the 5 GHz band to Short Preamble. I think it's a bug somewhere but have not reported it yet
Message 4 of 5
sachb
Tutor
It doesn't work here either. Also UPnP is broken on the latest version of the RAX80 (V1.0.5.132_1.0.69)
Message 5 of 5
Discussion stats
  • 4 replies
  • 1393 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
