Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX80 behind RAX200
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-25
08:00 AM
2020-03-25
08:00 AM
RAX80 behind RAX200
I have 3 areas with soundproofing construction techniques implemented that cause enough interference that wireless does not penetrate well enough from one area to the next to be useful, but some weak signal does show in each area outside the main. I need wireless in each area, preference being all interconnected and broadcasting the same WIFI network SSID so that mobile devices (cells, laptops, etc) can traverse from one area to the next seamlessly to the end user. I have a RAX200 setup and working connected to a cable modem and two RAX80 currently unboxed and firmware updated but not configured. I have ethernet trunk lines in place that can connect the RAX80's to the 200 in the two "remote" areas. What configuration options do I have to deploy these in the manner described?
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router, RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-25
09:00 AM
2020-03-25
09:00 AM
Re: RAX80 behind RAX200
I wouldn't go that route unless you didn't have an option. The RAX line aren't mesh setups.
If you want roaming options, look to the Orbi line of products. Plus you can add in satellites as needed for extra coverage.
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-25
09:05 AM
2020-03-25
09:05 AM
Thanks, but I already have the gear described. Is there a way to make this work with these three RAX devices?
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-25
09:09 AM
2020-03-25
09:09 AM
Sure you can hook them up and run them with the same ssid's. Make sure the 2 RAX80's are in ap mode.
It isn't going to be seamless like the orbi setup but it'll work. Devices might tend to be a bit sticky and not transition from one router to the next though. That's where the orbi system works well versus just using the same ssid for a router-ap setup.
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-25
09:49 AM
2020-03-25
09:49 AM
Ok, understood. I'll test it out. In AP mode, I can still use the ethernet trunk lines without them attempting to bridge together wirelessly, correct?
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-03-25
10:16 AM
Announcements
