- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX80 has no fan?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm on my second RAX80. There is no fan inside that I can see.
The first one I purchased used thru Amazon, and a week or so later I found a new one on sale by Amazon for a little less that the price as I had just paid for the used one. Used one is not covered under Netgear warranty (warranty is only for original purchaser), the new one is, so I ordered the new one. Free return, so I net a few dollars.
The first one worked fine. The fan would come on occassionally, and it could easily be seen through the top mesh grill...label, tiny blades spinning or not. I could feel the breeze when it was on. Wasn't very loud at all.
The new one arrived. I installed it. It is working well. Sent the first one back for refund. All good.
I had never heard the fan on the new one, so I looked through the grill...there is no fan. Flashlight through the grill. Nope, no fan.
I know model configurations change over time, but since I have seen/read a few posts here about fan noise and heat on this model, I thought I'd ask here: am I missing a fan, or is all well and I should move on?
(There is nothing wrong with the device, so didn't really think I should create a service ticket at this point.)
Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi jcax,
All RAX80s are built with a fan. If you believe your device doesn't have a fan, I would suggest contacting our support team.
https://www.netgear.com/support/default.aspx
Christian
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi jcax,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
