- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAXE500 Schedule Not Working
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's wrong here? Yes, I hit apply. Yes, it is in 24hr format. Yes, time zone and DST are set. I also tried a suggestion of flashing the same version firmware.
Hardware Version | RAXE500 |
Firmware Version | V1.0.9.78_2.0.38 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAXE500 Schedule Not Working
What's not happening? What are you trying to set here?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disable internet access for all devices in the time frame outlined.
I foster children and I know if I don't disable services overnight, they will be playing on the internet when they should be sleeping.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have Access Controls enabled for these devices as well...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not. I will look in to that. The directions only mentioned the Time Zone settings needed checked.
Thanks for the advice!
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can use Block Sites or Block Services with a schedule. I had to make multiple per device rules. This certainly could be made much easier if you could use Access Control and put in a schedule per device or selection of devices.
