× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Rax120 question
danielshaw007
Rax120 question
Hi all. I don't live in a fibre area so using an ISP provided 4g router. Works well however I have an rax120 on way from amazon.
This ISP router has no options to turn off the DHCP.
I plan to turn off the WiFi on my isp router and use the RAX120 to handle the all the wireless traffic.
Question is, will devices use the netgear dhcp first if they connect to this rather than my isp router ?
If I plug my isp router into the WAN port in the netgear one will it work as I have described above?
Alrernative if I set the netgear to AP mode and just collect it to the LAN on isp router will it still have all the features available ?
I hope you understand my question.
Thanks
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Guru
Re: Rax120 question
here's what features get disabled:
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Another option is to see if the ISP modem/router has a DMZ. If so, you can set it with the netgears IP address
Message 2 of 2
Discussion stats
  • 1 reply
  • 566 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
