- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rax120 v2 constant random rebooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rax120 v2 constant random rebooting
1. what modem/gateway is it connected to?
2. what firmware is on the router? (actual number)
3. how do you know its rebooting? (details)
4. how frequently is it rebooting?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rax120v2 is running 1.2.1.22 and have tried all previous versions
We loose internet on all devises and all lights go out on the router then it comes back on with a blinking power light and continues to boot up normally. Somtimes it won't do it for hours sometimes it will reboot every 5 mins. I just read about turning the ax mode off so I'm giving that a try
- Mark as New
- Bookmark
- Subscribe
- Permalink
What actual arris modem is it?
Have you tried different power outlets?
Whenever the original and a replacement have the same issue it makes me check other factors. Maybe the outlet has a sketchy connection and the cheaper/old routers dont have the same power requirements or tolerate fluctuating power better.
If you go modem---->cheap/old router----->rax120 and then put the rax120 in access point mode (prevents double nat) does it stay stable?
Again, just trying to check different things.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried 3 diffent outlets on completely diffent circuits
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it helps, I found that when a Roku Express was connected to my RAX120, it would cause it to reboot every 15 or so minutes. As soon as the Roku was powered off and disconnected from the network, my RAX120 has been solid for days without issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Joe1234567 wrote:
I ruled out AX mode being an Issue and also i set it into AP mode and still rebooted
- Mark as New
- Bookmark
- Subscribe
- Permalink
We just purchased the same router, new from the NetGear store and we are having identical issues as posted above. The router will reboot at random times, sometime 5 minutes, sometimes several times an hour. Sometimes it's so frequent that it's tough to get any work done. We have 4 total wireless devices connected to it. FireStick V1, MacBook Pro, iPhone 10, iPhone 12 It is plugged into a ARRIS SBG6700-AC that is running in bridged mode. The power outlet is good. Hardware RAX120v2 and Firmware V1.2.1.22 . I really was liking this router because of it's long range WIFI, but this instability isn't going to work. I just noticed while typing this post that my iPhone 12 keeps dropping the WIFI and switching over to cellular, I'm sitting 20 feet away from the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same issue, the support tech for today suggested it was because of the DoS attacks, but after reading many threads I don't think that is the problem. It's randomly dropping just as the above has suggested, and i'm not sure what to do here. today is the last day to return it and i love the highspeed wifi when it works, but i'm just not sure that the amount of drops that have been happening (increasing in volume) are worth while.
Does anyone have any ideas on how to fix this.
I've done the following.
1. reinstalled hardware firmware
2. Factory reboot and re-install
3. Moved to wall based power
4. endless hours of netgear support
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wanted to update this thread. Found out the kids had turned on a really old Amazon Fire Tablet. Each time it access the internet it causes the router to reboot. I threw the tablet in the garbage where it belongs and the router seems stable now for most of the day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was nice while it lasted. With only 2 devices, a MacBook Pro and FireTV, the router is rebooting over and over tonight. This is frusterating for such an expensive router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess my experience with my Nighthawk X10 R9000 led me to puirchase another NetGear which is how I ended up with this AX12. The Nighthawk X10 device I have at another property has 50+ devices including 16 security cameras, TV's, tablets, Plex Server, x2 home offices alll hooked to it and it has never rebooted or had any problems. It is truely the best router I've ever used. I guess I'll just look for a used X10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I replaced an X10 during the first quarter of 2020 with an RAX200 AX12 router. The X10 was great but wi-fi 6 was appealing.
The RAX200 worked OK for the first few weeks with random reboots. I tried many troubleshooting steps and then I ran out of my return windows. Random reboots got worse! Basically the router failed!
Contacted Netgear which was absolutely no help.
My experience with RAX200 was remarkably similar to the initial poster on this thread. I tried everything and finally gave up and bought a new ASUS router. I configured the ASUS and everything worked as represented. I put the RAX200 in a box hoping for miracles but not expecting one.
2 months later I viewed a video where some guy took apart his Netgear router and fixed some kind of random issue. I did learn how Netgear puts devices together and how to take them apart. So I decided to take a day and see what the RAX200 looked like inside since it had no value to me as it was.
I do not RECOMMEND anyone try this but I thought that I would SHARE my discovery!
I discovered that the Power Adapter plug that powered the router seemed outsized and that it did not seem to fully insert into the socket on the router mother board . I also found the socket on the router mother board was not properly soldered and secured to the mother board (ie. it moved around - up and down). I could not fix the solder joints but I had the idea to put a non-conductive spacer between the MB and the socket module preventing it from moving up and down. It took me several hours to get this done and get everything back together because I am very much an amateur. Aftert this bit of "jury rigging", I found that the power plug would fully insert into the socket which wasn't possible before.
I decided to try the RAX200 in its former place of honor which had been taken over by an ASUS. Wow! It worked perfectly. The power adapter plug fit fully into the socket and it have been running for 2 months without a reboot. I have multi-gig internet and numerous peripherals that now work perfectly. I realize that my amatuer fix may fail at some point but I feel quite satisfied that I have gotten something out of my $500 investment and that I can once again experience network excellence.
I also recently added an RAX120 in another area of my house that has worked perfectly since day 1.
It seems to me that quality control at Netgear has not been up to its, heretofore, high standards. Perhaps, my story of disappointment and discovery can lead to a return to quality control that has made Netgear's reputation what it is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well add me to the list. Reboots in the evenings, just after dinner strangely. I have no idea what to do other then return it if I can. I have done everything to dumb it down, set configs, etc.
