× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Router Security Question Nighthawk RAX120
morete1
Looking at my router logs in advanced settings, I noticed that I got a DDoS attack on port 80.  As far as security goes with my settings, I use WPA3 for the 5GHz and WPA2 for the 2.4 GHz.  Are there any other router security settings that Netgear has to help prevent these DDoS attacks on my home network?  I use a #3 rated paid anti-virus/firewall program recommended by popular independent A/V software reviewers, but my A/V software didn't stop the DDoS attack because it wreaked havoc on my network.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Router Security Question Nighthawk RAX120
morete1,
Most DoS attacks have been reported as false alerts. However, we do recommend that you are on the latest firmware for security/performance purposes.
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 1154 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
