× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Security Access Control is out of control after devices over 20-30
HowardLu
Hi, Netgear:
I met big problem about access control when it is turned on.
I turned on access control, and checked "Block all new devices from connecting"
Block function is worked, but after 20 - 30 clients connected, I make some clients to "allowed". but it cannot be "allowed", and when I reboot device, some "ever allowed" clients change to blocked. and I also observed the access control menu is always refreshing and become slower, very hard to show this page.
When saw this symptom , I found another issues is that all buttons cannot be controled.
To fix this problem, I need to factory reset to make it recover, but when all clients are relogin, this symptom is happened again.
Please kindly fix it, I listed device info here.
Hardware VersionR1.05
Firmware VersionV1.0.3.80_1.0.1
GUI Language VersionV1.0.3.80_1.0.0.14
Thanks,
Howard.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: Security Access Control is out of control after devices over 20-30
Hi Howard,
May you revert to the previous firmware version and let us know if your issue persists.
https://kb.netgear.com/000061392/RAX40-Firmware-Version-1-0-3-64
Christian
Message 2 of 3
HowardLu
Hi, Christian:
Thanks a lot,
But when I roll back to V1.0.3.64,   WIFI function become unstable, it continued to ON and OFF automaticaly.
Need to use latest firmware to make WIFI worked.
BR,
Howard.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 595 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
