× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Still need a modem? Ax4300
Johjohjus
Follower
Do I still need a modem to work with this ax4300?
Message 1 of 3
antinode
Guru
Re: Still need a modem? Ax4300
   What is your "this ax4300"?  "AX4300" is a speed, not a model number.
Look for "Model" on the product label.  RAX45?
   With that datum in hand, you might try a radical concept which works
for some people:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual (at least).  Read.
   "still"?  Did you need a modem before?  With some other (unspecified)
router?  The non-psychics in your audience might know very little about
your Internet service, or what your (unspecified) ISP might require, or
what you were using before, with what.
   A RAX45 is a router, with no built-in modem.  If your service
requires a modem, then I'd expect your service with a RAX45 to require a
modem, too.
Message 2 of 3
How do you get the Internet?
If you have an Internet service provider that fixes some sort of box to the wall, that may be able to feed a router. But that is usually "fibre to the home" Internet.
A good place to ask the question is with the ISP that sells you the Internet service.
Message 3 of 3
Discussion stats
  • 2 replies
  • 897 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
