- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Trying to set up a 2.4 Ghz on my CM1100
- Mark as New
- Bookmark
- Subscribe
- Permalink
Am trying to add a 2.4GHz connection to my exisitng 5GHz setup, when I follow the instructions and try the 192.168.100.1 route and check 'advanced setup' I get no option for the setup here.
Any help? what should I do - I have a Eufy WiFi and a smart light, which only work on 2.4GHz and I can not set them up.
Some details about the equipment
Model: CM1100
Purschased: Jun 2020
Existing setup: 5GHz (want to retain it and add a 2.4GHz band)
Provider: Xfinity Comcast
Firmware: V7.01.01
Hardware V: 2.02
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Trying to set up a 2.4 Ghz on my CM1100
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
The CM line of modes do NOT have a built in router nor wifi capabilities. You need a extneral wifi router to connect to the CM modem.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
